Sonic core drilling - geotechnical application
I want to find out if anyone has used sonic core drilling for soil sampling for geotechnical purposes.  I know its used a lot for environmental work but I am interested in its usefulness for geotechnical subsurface characterization.  Conventional drilling and sampling will be done (this is s tunnelling project in soils).  Can sonic drilling provide good startification that might be useful?  Is that the only use of this technique for geotechnical purposes?
Thanks for your help.
RE: Sonic core drilling - geotechnical application
earth321,
I was involved with a project that used a sonic rig. We used the rig because we could get a continuous sample and because in the hard till we were going through, it would not have been possible to use hollow-stem augers (we were setting groundwater monitoring wells), i.e., it was faster. Like waaaaaay faster. It was also expensive, but worth it due to the time savings.
The logistics were a little more complicated as the sonic trucks were heavier than conventional rotary rig trucks, but being able to plow through 50-odd feet of some very hard till and set casing was well worth it.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
