Solidworks Intersection Curve Question
Hey all.
I have a surface for a catamaran that I modelled and I have used the intersection curve command to create horizontal sections every 5 inches from the bottom of the hull to the top of the hull. For some reason in the 2D translation of my part, these sketch curves are only visible in the bottom view of the drawing. In the front and side view they are not visible
Is there some rules I'm not aware of in regards to the visibility of sketch geometry in the drawing portion of solid works? It will be difficult for me to do a view of each section if I can't create a section view using the front or side views.
Dave Shaw
RE: Solidworks Intersection Curve Question
Expand those views in the tree, find the sketches, right click and show them.
good luck
Jason Capriotti
Smith & Nephew, Inc.
You can force the visibility as Gildashard states, but then all you will see is a horizontal line. Is that what you are after?
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Thanks guys. I didn't know you could expand the directory tree in drafting.
Later
