Estimates of launch vehicle pitching rate
Hi all,
Are there any online resources that have figures for the pithcing moment or rate of a Delta II during ascent into LEO?
Thanks in advance.
RE: Estimates of launch vehicle pitching rate
http://stardust.jpl.nasa.gov/mission/msn.html
would allow you to make a reasonable guess. You'll need to get a bit more specific about the configuration as Delta II has a few options (from what I can tell).
There is a Boeing Payload Engineer's manual, but I cannot find a live link to it.
Cheers
Greg Locock
Hi and thanks for trying to help.  I looked at the link you gave me and I don't understand how I could make a reaosnable guess from that information.  It's not to scale and no pitch orientation info is given.  By the way, the data I seek is for the Delta II 7320-10C.  I also have the Payload Planner's Guide for the Delta II, but it doesn't have pitching data in it.  I assume that the pitching data would also be a function of the desired orbit as well, but I'm just looking for representative values.
Can anybody help me with this???
Many thanks.
You need to construct a speed vs altitude model to agree with the data shown, and the known performance data for the rockets. Then you can work back to a pitching rate.
It'll be of the order of one degree per second.
Cheers
Greg Locock
Okay, I'll give it a try when I get some time.  I don't need an exact answer, just a typical worst case number.  Thanks.
