PDF Creation Help
PDF Creation Help
PDF Creation Help
I have set up my NX2 plotting with the following switches:
/384/17/AR/AS/D=800/MO/SP
I get a pretty good PDF after I distill the .ps file UG creates but the dwg is rotated 90 deg and there is a bit too much white border for my liking.  I would like to know if anyone knows what I could do with the switches OR in distiller to fix this stuff.
I mostly do D size to 11X17.
Joe
RE: PDF Creation Help
Joe,
You can set up a plot Q for each size drawing.
the plot switch that I use for D size plots is
/SP=MW/AR/PG=34X22
to set up a C size plot just change the page size (PG=??x??)
Jeremy
