Demoulding agent on cold cure foam
Hi! I work in a cold cure PU foam plant and im looking for some technical information on demoulding agents, specialy for information about how the composition of the demoulding agent affects the build up in the mould.
I cant realy find anything interesting on the net. Any tips?
RE: Demoulding agent on cold cure foam
There is tons of information on the net if you use
"release agents".
