Solidworks and MathCad
Solidworks and MathCAD
Has anyone tried this integration yet.
(Need SW2005 and MathCad 12.1)
I have started to play with some of the examples that came with the download, and the integration seems to work nicely. I can see a lot of potential for this.
I am having trouble getting it to work on parts I have created. When I create a part and insert it as a component in MathCad I cant seem to get the script to command the SW model at all.
If anyone has figured this out yet or if anyone experiencing the same problems let me know.
Probably some setting I'm missing.
DG
DG
RE: Solidworks and MathCad
It mentions nothing about being able to manipulate a solid models geometry. Is that what you are trying to do? Is that what Mathcad claims it can do?
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
The solidworks model sits in the MathCad sheet and will update as you change variables associated with the model.
You can double click on the model in the MathCad worksheet and editable solidworks opens in the worksheet.
(Think of editing an excel table in word or soliworks.)
The regular website doesn't mention anything about it because it is something that was just released as a feature to the software.
MathCad and Solidworks have partnered so to speak.
For those interested check out the following link.
www.mathsoft.com/solidworksintegration
3D plots/graphs turned directly in to a solid model for prototyping. A great addition to SW.
I missed the webinar they had recently on this subject and unfortunately, if MathCad 12.1 is required, I'll be out in the cold for a while. (currently still using 2003 (v11))
Remember...
"If you don't use your head,
your going to have to use your feet."
See
http://www.solidviz.com/mathinworks.htm
This allow for the Mathcad functionality from within Solidworks.
However, I believe MathCad 12.1 is still required.
DG
Sorry. I'm confused here. Is there a sample in SolidWorks or Mathcad? "Has anyone tried this integration yet. (Need SW2005 and MathCad 12.1)...."
Or is this with the MathInWorks addin?
Or do you insert an object in Mathcad or SolidWorks?
Could you clarify. I'm interested in combining the two also.
Thanks.
Christopher Zona
Litens Automotive Partnership
Concord, Ontario, Canada
You can download several files from the mathcad website
that allows you to insert into a MathCad document a Solidworks object.
What you get is a window inserted into the document where you can see your model.
There example is pretty simple but in use I think this could be pretty powerful.
They show a wheel with lug holes and a central hole.
As you change the mathcad values for lug diameter or wheel diameter etc. the solidworks incorporated model updates in real time to display the changes.
If you double click the model graphic, solidworks is loaded inside mathcad and you can make other changes to your model via solidworks. Click somewhere else on the mathcad worksheet and the mathcad document is active again.
I have tried to use my own models but have had trouble getting the object script to link to solidworks as they have done.
DG
I have seen the MathInWorks, but what I describe above doesn't happen from within SW it happens from witin MathCad and is a free add-on from MathCad.
DG
