How to polish the SKH 51 by electrochemical polishing?
I have some rollers made by SKH 51 material. Could i use the electrochemical polishing technique to polish the surface of the SKH51 rollers?
SKH 51 (C:0.8~0.9, Cr:3.8~4.5, Mo:4.5~5.5, V:1.6~2.2, W:5.5~6.7)
RE: How to polish the SKH 51 by electrochemical polishing?
http://www.welding-advisers.com/
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Are they mounted of unmounted?
How critical is the diameter?
What are the quantities that need to be processed?
This size component is normally call a pin.
the pattern's high is about 10um
the quantities i need is about hundred
Is there any efficiency way to do the process?
You might be able to laser scribe the surface to get the same effect.
It the same as EdStainless's reccomendation.
If so you will need to talk to people like the following. Either ECM or Laser machining with Laser probably the best bet.
http://www.ex-1.com/
http://www.tech-etch.com/photoetch/index.html
