Internal Volume of An Assembly
Does anyone know how I can automate the process of determining volume inside open chambers of an assembly containing multiple components?
i.e. I have a design for a 4 pass SS heat exchanger consisting of a primary tank, collector boxes, secondary tubes and a flue.  Knowing the internal volume is very helpful in determining air changes, back pressure, etc.
Thanks for any Help,
Brian
RE: Internal Volume of An Assembly
The only thing I can think of at the moment is to create a part that represents the internal areas and then open that part and get a volume of that part using Mass properties.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.0
Try jksolid's suggestion and use the Cavity command on the new part.
