Divide Command and Dimensions show different values?
Hello.
Software: ACAD 2005/2006
Situation: We divide say 100ft of wall and add undersizing ie. 3/16". Basically when I divide a line and try and dimension the nodes some of the dims are slightly different. Ie 7/16" or 5/8" or something like that. When I used the distance command every node is exact. We have our units precesion of the drawing set up to 1/256".
What controls this? Is it the Round off or the Precision in the dim style?
Our dim style is set to 1/16" precision (which we want to show on the drawings) and roundoff 0" which I'm not sure is correct.
When we dimension stuff up I want everything to be exact but when the dimension shows it displays on to the 1/16"?
Anyone help on this?
RE: Divide Command and Dimensions show different values?
or snap settings.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
thanks
Matt
