Using VB to create an HMI for Siemens PLC
Hello all,
I am looking to write an HMI in VB6. This code will read/write bit data from a Siemens 222. This is for a test station, nothing fancy... I have done this for AB SLC's, but never Siemens. Is it even possible? Any links to source code or drivers is appreciated!
Thanks in advance.
RE: Using VB to create an HMI for Siemens PLC
We are doing this to S7 318 using Parijat ActiveX.  They have a demo you can try. Parijat.com I think is the address.
hi Electromechanical30. I have just done this with excellent results although i used the VB dot net structure. vb6 is still supported. what you need is Siemens Prodave. I found any help from siemens was a bit less than supportive than they should have been.(I put this down to their vb skills) basically you are buying a couple of DLL files that start the communications, read /write and close the communications. as required. I used prodave mini which looks at the data blocks. its fairly simple and at a much lower cost that buying WINCC. Prodave costs about £150 and when you have this there are no license limitations for further applications.
good luck
multimeter1
