Could not open
Could not open
I am a new user of NX3 and seem to be getting consistent errors with parts, not assemblies. I thought its cause may be related to my backing-up but now find it not so. When a file has failed to load I get messages "could not open", "could not be loaded" and "internal error". What is the cure for this frustrating problem?
RE: Could not open
Load options point to the new components files directory in NX3 path with “…” and files are saved as necessary and prior to closing. The check box for “use partial loading” is checked and not sure if that is a problem or not.
I would be pleased to update this if you have remaining questions. Thank you in advance.
Charles Bruhn
RE: Could not open
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: Could not open
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
