Polymer mixture - gallons to Lbs?
I have a mixture of 7.5 ml Polymer to 1 gallon of water. how do I calculate the gallons used into lbs? I was given the fomula of Polymer gallons used times .016 but that doesn't look right. In the case of say Alum, it is the gallons used times 5.4.
RE: Polymer mixture - gallons to Lbs?
