gas expansion calculation
I am flowing 100 sccm gas through 10 orifii of diameter 0.016". The gas is either B2H6 or BF3.
I want to do a gas expansion calc to determine a minimum pressure gradient needed to establish a sonic front.
RE: gas expansion calculation
To determine the pressure drop, either upstream stagnation pressure or downstream static pressure must also be given.
In this case, downstream static pressure is 6, 8, or 10 mTorr.
The crictal pressure ratio of upstream STAGNATION PRESSURE to downstream STATIC PRESSURE =
[(GAMMA+1)/2] RAISED TO POWER [1/(GAMMA-1)]
WHERE GAMMA IS RATION OF Cp/Cv
