Patterened Items in My Feature Tree
Is there a SYSTEM PROPERTY that controls whether or not patterened items show up in my feature tree. I like them at the bottom - within the pattern feature - but they're also showing up in the "body" of my tree & really cluttering up the joint. Even if I place them in a folder - there's still a butt-load of them & I see no reason to have them show-up twice.
Thanks...
Thanks...
SolidWorks 2005 SP01.1 / Windows 200 Professional
RE: Patterened Items in My Feature Tree
Similarly, if you have created a component pattern within a sub-assy, then that pattern will show up at the bottom of that sub-assys tree, not Aat the bottom of the Top Level assy.
If I've misunderstood your question, please post an image of what you mean (FAQ559-1100)
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
I have some parts & hardware in my assembly & I place the hardware with feature driven patterns where possible. I want to see only the original nuts & bolts in the feature tree - not the patterened ones.
When you say "patterened items", do you mean the Component Pattern Feature or the actual components that were created by the pattern? If you've got the components showing up in the middle of the Feature Tree, and the Component Pattern Feature is *not* there, then that means at some point someone RMB the Component Pattern Feature and selected "Dissolve Pattern". If that's the case then to fix it you'l have to delete all the additional components that showed up after the dissovle, and redo the Component Pattern Feature(s).
Ken
Are you sure they are the same parts. If you delete the ones in the tree (not the original seeds), do the ones in the Pattern Feature (at the bottom) also get deleted?
Can you show a screen shot of your expanded tree?
[url]http://webpages.charter.net/tater/SWX/ETF-001.jpg[/url]
Now I'm gonna CNTL-right-click & hide components.
[url]http://webpages.charter.net/tater/SWX/ETF-002.jpg[/url]
Notice now - that most of my hardware - in the feature tree - is hidden. If I expand the pattern features - I'll see the same hardware parts - hidden.
[url]http://webpages.charter.net/tater/SWX/ETF-003.jpg[/url]
I don't need to see the same parts in more than one place in my feature tree. How's that for clarification?
Do you have a similar assembly where a folder has never been used? Does it have the same problem?
It never occurred to me to try that.
Just another endearing SolidWorks quirk I guess.
Thanks Limey
Jason Capriotti
Smith & Nephew, Inc.
