CompositeCurve Surface Fill
Why can't i use a composite curve as a boundry edge for the surface fill command.  I ended up created a 3dSketch (spline)on top of the CompCurve to use as the boundry edge.  What gives?
RE: CompositeCurve Surface Fill
Is it a closed boundary? If so, why do you need it to be a Composite curve?
On top of that a composite curve is not an eligible entity that SW will use for a fill surface command. The fill surface command require either edges, or sketches.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Yes, its a closed boundry.  However the boundry consists of over 250 edges. I tried to select the edges, but could not get the surface to work, so i created a 3dspline instead of click all the edges.  Select Tangency was no good.
Is Loop selection an option?
Jason Capriotti
Smith & Nephew, Inc.
Another thing to try:
Generate your composite curve.
Next create a 3D sketch and convert your composite curve.
Then select the 3D sketch as your boundry edge for the filled surface.
For some reason this seems to work for me.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.0
You can't use a composite curve, so you wil have to use a sketch or a combination of sketches and edges, as long as it's closed. If it doesn't accept it then it's not closed. It may looked closed, but it's not. And that could be a small factor that it's off by. So do check it from different views.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Really?  You can get a 3D sketch to work as a boundary edge?  That's good to know, since I tried the composite curve idea with failure in the past as well.
Gildashard mentioned what I do with lots of edges.  Select an edge, then right click to select "loop" or "open loop" or "tangency" or whatever ends up working.  After you make your selection, then use the fill feature.  Works well.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
