Suction Pressure Locked Question
If we take the case of a drinking straw in a glass of water. Placing you thumb over the top of the straw and lifting it from the water will lift the water in the straw, until your thumb is removed.
Question. How large a diameter can the straw go to before this no longer happens? Is this phonomena something to do with surface tension of the water?
RE: Suction Pressure Locked Question
It is about 10.033 meter or 33 ft .
If the straw is filled with mercury you can lift up about
29.52999 inchs
The phenomema has to do with the atmospheric presure.
Search for TORRICHELLI and how it demostrate it.
www.cadtutorforum.net
Scientifically we visualise the phenomena the other way round with atmospheric pressure (10.33 m head of water) pushing up on the bottom of the water column. Since all you have at the top of the water column is a vacuum the only force pushing down is the weight of the water and since you have a pressure of 10.33 m pushing up then you can theoretically support a 10.33 m high water column. (In practice you don’t get a true vacuum – the water vaporises at the top of the column and the minimum pressure is vapour pressure – but don’t worry about that).
Brian
"How large a diameter can the straw go to before this no longer happens?"
"This" refers to the ability to raise the straw without the captive water draining out of the straw.
I believe hyposmurf and BRIS don't address the issue. They merely reflect on the well-known ability to raise a column of water using vacuum as a driving force. The diameter of the straw does make a difference on the ability to be able to raise the straw out of the water (with the vacuum intact) and not have the water drain out.
JStephen is closer to answering the question.
Since the surface of the mercury - when in a glass straw is concave - it must be in compression !.
otherwise, all the water in the oceans and the atmosphere would be sucked into space (full vacuum)
Thanks to Newton, who invented gravity, we can live in this planet. :oþ
this has to do with capillarity and surface tension vs. the weight of the column of liquid.
see:
http://www.du.edu/~jcalvert/math/hyperb.htm
a rough (very rough) experiment is this:
fill a glass with water.
place a plate or a piece of cardboard on top.
carefully turn it upside down.
if you did not leak, there is no air between the glass and the cover.
lift the glass.
clean the mess.
cheers.
saludos.
a.
Regarding the diameter of the straw, it is surface tension in combination with cohesion and adhesion that maintains the stability of the water, air, and glass interface at the bottom of the straw. I don’t think that you can have surface tension without cohesion??? Any instability in the fluid that is greater than the bottom surface tension of the fluid/air interface will cause the column of water to collapse by air entering the column. Hence, no matter how still you hold the straw when you raise it, there are still molecular motions that can “upset the cart” when the straw diameter gets large.
Surface tension definitely does play a part, but it is applicable to the bottom of the straw or pipe, and only when the bottom end is *not* submerged. As long as the bottom of the pipe is *submerged* in the main body of liquid, the diameter of the pipe or straw does not matter. The straw/pipe would remain filled with liquid water until its length exceeded 10 m (33 ft) and then if it was longer you would get water vapor forming in the volume above 10 m.
Things change as soon as the bottom of the straw/pipe is pulled out of the water. Now surface tension becomes important. If the surface tension is sufficient to stop droplets of water falling from the bottom surface, and to stop bubbles of air rising, then the water will remain in the pipe. Obviously as the pipe diameter increases there will be a greater likelihood of droplets falling.
There was a time when I could have done the force balance on the bottom surface, but those days are long since past. You can read it up in your old physics books as well as I can, so I will leave it to you to calculate the maximum diameter.
abelito describes something similar to which I've done countless times in the lab and out in the field - like reading the pressure drop across an atmospheric packed column. However, we Chemical Engineers do it the classical way: we construct a barometric Mercury gauge (a "U" tube) by submerging it totally in Mercury until all internal air is displaced by the liquid Mercury. We then raise the filled tube out of the water and let gravity take it's effect on the sealed end of the "gauge" and we have a barometer! It can also be done with water as the fluid. I don't agree with abelito's description. This is not a "rough" experiment; it is very exact.
The same can be done with a conventional glass of water: submerge the empty glass in a tub of water, turning it right-side up beneath the water level and expeling all the air. Now, turn the glass upside-down (under water) and slowly raise it up and out of the water (without taking it totally out of the water) and you will have created a "perfect" vacuum in the top of the glass (due to displacement by water). A perfect vacuum will raise water to a height of 33.89866 ft (according to katmar's excellent conversion program that every engineer should have and run) so the glass should be longer than that to show a water level.
Bris' static theory falls simultaneously with the contained water when the conventional full water glass (with a pure vacuum) is slowly raised (upside down) out of the parent water tub. As abelito infers, the truth of the theory is revealed when the wet mess has to be mopped up. The fact that one can do this operation successfully with a straw, but not with a glass of water proves that the diameter of the circular apparatus is an important factor on whether the operation works or not.
If your jar is 100 mm tall, atmospheric pressure is 10.0m the pressure of the partial vacuum will be 9.9m (or - 0.1 m gauge)..
It is the Van Der Waals forces between the molecules that prevent molecules dropping out of the straw and also prevent the air, that is pressing on the bottom of the liquid, from permeating up through the liquid - surface tension is a phenomenon of the intermolecular Van Der Waals forces. But the water is not held by adehesive forces forces between the liqued and the walls of the straw and this is what appeared to be being implied by soome of the answers that it is surface tension forces that is holding the liquid in the straw.
In conclusion the limit depends on how steady you can hold the straw and how smoothly you can withdraw it from the bowl. The difficulty is maintaining a steady withdrawal as the cohesive bonds are broken. To really get to the limit you would need to set up a rig to give a constant rate of extraction.
Brian
