API 650-Distance from bottom plate to shell welds
Please advise us. We need to know what is the minimum distance between an annular plates joint weld and a vertical (shell) plates joint weld.
Please reference the applicable API650 paragraph.
Thank you in advance.
RE: API 650-Distance from bottom plate to shell welds
API-650 does not specify a minimum offset between these two joints.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
