Problems with inverse Transfer Function Filter
I'm working on a inverse-TF-filter for compensating attenuation of my system.
Description of the System is:
Labview(sweepsignal(mag 1, 200-20Hz, 30sec):Fileoutput) - Amplifier - Shaker(B&K) - Tube - PCB-acc-Sensor - Labview(input)
The idea is:
measuring the Transfer Function with white noise.
inverting the TF
bring it back to time-domain by iFFT (impulse response)
convolution with sweep-signal
output filtered sweep file
I now expect a constant magnitude while measuring the vibration from the filtered signal.
But I received a signal which contains some kind of modulation with a low frequency.
(I worked only with the magnitude-part of my signal)
I hoped eliminating this effect by adding the phase-shift by complex-calculation but then I receive a signal 10 times higher as I need....
Another problem is, when I turn up the amplification of my shaker in an area that my filter has to attenuate the output signal - I still receive a impuls response which amplificates the sweep instead of scaling down the magnitude...
Does anybody know something about this problem?
The idea is:
inverting the TF
RE: Problems with inverse Transfer Function Filter
