seawater boost pump in ro application
I'm seeking my most cost effective solution.
240 gpm flow; input 745 psi, output 820 psi; continuous operation. new, or used if anybody has this puppy laying around.  thanks.
RE: seawater boost pump in ro application
There is an interesting device called a hydraulic turbocharger that you may want to look into.  There is information on it at:
http://www.pumpengineering.com/
