Plotting on a HP 800 42" from ProE
We are running ProE Wildfire and we just purchased a HP 800 42" plotter. When plotting a standard D size drawing from ProE I keep getting the leading and trailing edge borders cut-off due to the standard margins within HP (.7" per edge). Does anyone have any suggestions on resolving this issue, it is driving me nuts????
RE: Plotting on a HP 800 42" from ProE
It seems to be a Pro/E issue versus the HP or Adobe print drivers.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Do you trust your intuition or go with the flow?
No I have not. How do you go about doing this?
Thanks for your help.
I don't use WildFire so I'm not sure. You would have to do a search on the help files.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
