vibration conversion
how do i convert a vibration reading in dB and G's to Hz? This is reading of the floor slab on grade.
RE: vibration conversion
TTFN
TTFN
M
Dr Michael F Platten
Cheers
Greg Locock
Furthermore, some ISO standards require the floor velocity in terms of a one-third octave spectrum. The amplitude in each band is represented in terms of RMS velocity.
This format is called "Generic Vibration Criteria (VC) for Vibration-Sensitive Equipment."
Tom Irvine
www.vibrationdata.com
Try using 1 G for your reference level; in the eqn L = 20 log G's
That is, G's = 10^(dBg/20)
Good Luck!
Go Mechanical Engineering
Tobalcane
AdB is re: 1 micro g
then there's pk vs RMS, ISO vs ??
http://www.dliengineering.com/section.asp?nID=19
This one has a unit of "AdB" for acceleration and "VdB" for velocity in decibles.
