ACI 318 95 vs 99
ACI 318 95 vs 99
ACI 318 95 vs 99
I am trying to find a document which might list the differences between the ACI 318-95 which is referenced by the UBC with the ACI 318-99 referenced by IBC 2000.  I understand that there are not much differences but a comparitive chart would be helpful.
Thank you
RE: ACI 318 95 vs 99
Doesn't the 99 document have vertical lines in the margins showing what changed?
You do know that there are 318-02 and 318-05 editions out, right?
I am aware of the bars next to the revised material in the 99 and also have a copy of 05.  But the primitive land of California still uses the 1995 version per the UBC.  But thank you for your response.
