Transfer UG data to CATIA V4.20
What's the best practice for transfering UG data to CATIA V4.20 - and having a solide?
I have to get UG data into a CATIA .model file
The transfer succeeded, but our customer was not able to create a solide from my transfered data.
It containes only 1 skin, as I can remember from lightyears ago you need to have 2 skins, before you can create a volume and from that volume a solide? Correct me if I'm wrong here.
The data was transfered by STEP 214.
Does anybody has more expierence with these type of transfers and has some tips?
Pascal
Pascal
RE: Transfer UG data to CATIA V4.20
iges should also work, but its not going to give anything but curves and surfaces
btw- a lightyear is a measure of distance, not time
