Converting from 3D surface to 3D solid
Who knows how to convert a 3D object modeled with surfaces
to a 3D object solid modeled ?
RE: Converting from 3D surface to 3D solid
Surface>Surface Stitching
or
Command:AMSTITCH
Select all surfaces and press enter.
In Surface Stitching dialog box select Optimal Stitching as Type and Part as Output.
You will create a stsic solid base part. It will be non-parametric although you will be able to add parametric solid features to it.
Thanks Steve!
Now, can you tell me what means " a stsic solid base part" ?
After using amstitch, MDT 6 replied: "a part was created" but this object is not considered a solid by Section or Slice commands.
Something is strange in this conversion.
What is your opinion?
"Stsic" was a misspelling that should have been "static solid base part". As I stated earlier this is a nonparametric solid similiar to an AutoCAD solid.
