Concrete Wall Slenderness
There is a question from a fellow structural engineer about a concrete wall slenderness ratio. It is an end wall supporting gable roof, 14m long. The height is 12m to ridge and 8m to eave. The wall is 8” thick with double reinforcement. Further, the wall is simply supported at top and bottom, also there is a concrete floor (lateral support) at the 3m height. It is apparently a slender wall and exceeds the limit without deflection check. He check and strength and deflection. They are okay.
The question is whether the wall is too slender? Can he use the mean value as the wall height? any other things he should check?
RE: Concrete Wall Slenderness
For most wall panel systems, we use h/50 as a good starting point for design.
Also, using two layers of steel in an 8" wall is a bit overkill. You would probably be more economical with a thicker wall and one layer of steel.
Question - why the mixed units?
The wall is 200mm thick.
