Assign Part Name To Attributes Using Grip
What is the code for GRIP to recognize a part name and assign it to the part attributes. The file name is GE81001234.prt. I want the attributes to read Title = Part Name and the Value = 81001234 with no "GE" attached.
Larry Leonard
Designer
Smith-Nephew Orthopaedics
RE: Assign Part Name To Attributes Using Grip
assatt/part,'PARTNAME',substr(&partname,3,10)
It's all spelled out in the GRIP manuals.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Have not been able to put my hands on the GRIP manuals.
I have been looking to get assistance from our support people but decided to go on my own.
Trying to pick up as much as I can from the HELP files.
If you can help me further I would greatly appreciate it.
Larry Leonard
Designer
Ben Loosli
Ingersoll-Rand
ASATT/PART,'PartName',SUBSTR(&PNAME,3,10)
HALT
Ben is right in that the help files are a good place to get this from, but sometimes you need a nudge in the right direction. Since this is such a short program I'll explain what is going on.
ASATT/ - this is the key word used to assign attributes
PART - minor word that tells it to assign the attribute to the part rather than an individual entity
'PartName' - this will be the title of your attribute
SUBSTR(&PNAME,3,10) - this will be the value of your attribute, it has 2 parts so let's break it down further
&PNAME - this grip statement will return the current part name, in our case it would be GE81001234.prt
SUBSTR - this is the keyword to extract part of a string. The syntax is SUBSTR('string',<start>,<end>)
So, SUBSTR(&PNAME,3,10) tells it to extract characters 3-10 of the part name (in this case 81001234).
SUBSTR(&PNAME,3,10) will work as long as there are always 2 characters at the beginning that you don't need and you always want the next 8 characters. If the part name lengths are variable then the grip program gets more complicated.
2 - How hard would it be to have the TITLE: DESCRIPTION filled in automatically and then have a screen ask for a user entry for the VALUE:__________. (Just less trying for the user)
Larry Leonard
Designer
You could do it with a macro/NX3 journal.
GRIP can also ask for a value and then assign the attribute.
Ben Loosli
Ingersoll-Rand
How do I combine the code:
assatt/part,'P/N',substr(&partname,3,10)
Title: P/N Value: 81001234
popup on the screen will ask the user to input info
Title: DESCRIPTION Value: user input.
Title: MATERIAL Value: ALUMINUM
Title: FINISH Value: ANODIZE
Larry Leonard
Designer
Text/'Enter Value:',valvar1
assatt/part,'title',valvar1
It can get a lot more complicated with error trapping and good value checks.
Ben Loosli
Ingersoll-Rand
