1010 CQ STEEL SHEET CHEM. COMPOSITION
We recently received a chemical composition report on 1010 steel we are using in one of our products. All of the element wt %'s are within spec, but there is also 0.010% Si, and 0.056% Al, which are not specified. The remainder of 99.385% Fe is also in spec. What impact will these additional elements have on the properties, specifically formability, weld heat affected zone properties, and fatigue life (endurance limit)?
Svanden
Svanden
RE: 1010 CQ STEEL SHEET CHEM. COMPOSITION
