Display option for load/constraint symbols
Probably a simple question, but for a newcomer it's still confusing.
I want to display all of the symbols for loads, constraints, etc ALL THE TIME. When I apply a constraint, I see the symbols showing it has been created. After doing a few more operations those symbols disappear. I would like them to always be visible. I'm sure for large models it could get messy but my models are so simple while learning it would be very helpful. I assume there is some kind of display option but the help file has turned up nothing so far.
Thank You
Thank You
RE: Display option for load/constraint symbols
If you've applied the BCs to geometry, issue SBCTRAN to transfer them from the geometry to the FE model.
-- drej --
Thank you for your patience with a new user....greatly appreciated!!
