Pressure Relief Valve Selection
How to select pressure relief valve for domestic cold water piping? Pressure relief from 94psi to 60psi, the size of piping is 100mm. Thanks in advance.
RE: Pressure Relief Valve Selection
Pressure Relief Valves (PRVs) relieve at one set pressure. Why cite a range? Select the size of PRV that matches the highest water capacity you have at over-pressure condition. For domestic water you can do this using a catalog.
