Missing Configurations
I recently loaded a large SolidWorks assembly and I got the following message...
"The following component configurations could not be found.
"0008698.sldprt : Default
"0008698-1.sldprt : Default
"0021214.sldprt : Default
"0021214-1.sldprt : Default
"The last active configuration will be substituted in each instance.
I understand the missing configurations part. Someone renamed/deleted them. What I do not understand are the -1 filenames. Is SolidWorks looking for obsolete versions of the model?
JHG
JHG
RE: Missing Configurations
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
The files 0008698.sldprt and 0021214.sldprt are present, but the configurations are changed. It is actually someone else's model, which I was incorporating into a design of mine. The original designer is in for a surprise. Loading the file with write access, then saving ought to work.
I want to know why SolidWorks is searching for the alternate filename.
JHG
This would be my take on the situation. Somebody did a save as on a part while the assembly was open thus changing the part inside the assembly. I would do what Chris is suggesting replace/reload and recreate the configuration in the part which should resolve the assembly issue.
I did something similar the other day deleted a configuration in a part and when I opened up the drawing that referenced that specific configuration it blew up. So I closed the drawing then recreated the configuration. I then opened up the drawing and everything was okay. I was able to then modify the drawing.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Do you trust your intuition or go with the flow?
