Export UG assembly as individual step files
I'd like to export a UG assembly to either IGES or STEP and have the outcome be individual IGES or STEP files of each part in the assembly.  Possible?
Thanks...
RE: Export UG assembly as individual step files
Yes
You ned to do the export from the external tool or use the file on disk. You cannot do it with the active model.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Ben,
Please explain furthur.  I'm not a UG driver.  Former Pro/E driver trying to get stuff into Catia.
External tool?  I'm using iMan as well and thought I could do it there but Java problems are preventing this.
Thanks...
UG has an extaernal application for export/import translators. On windows, Start, UG version, Translators, which translator. Then you can select 1 or many files to translate.
Ben Loosli
Ingersoll-Rand
I´m not sitting on a UG station right now but I think it can be done from UG if you use export to step 214 (exports assembly structure and parts)
If you do it from within UG, you MUST select the file to be exported from disk, not the current work part in session. If you use the part in session, the output will be a flattened structure. This is documented.
Ben Loosli
Ingersoll-Rand
You can export step files with assembly structure in NX not sure about releases after that.
You have to make sure that all components are fully loaded.
When you export the step (in UG) and go to class selection you make sure you just hit ok (don't select anything).  This then selects all the components with solid bodies.
Mark Benson
CAD Support Engineer
