INcoming cable support/tubing
I am looking for help from the utility side of things. I have a swtichroom I am installing and need to bring a 600vac service into the building. What do I use for the incoming "tubing/mast"? It will be coming in via rooftop, and will need some sort of tubing. I was also thinking that it may need some type of insulator to secure an anchor to so as not to put to much tension on cables and the building. The cables will be 3c#2.
Does anyone have a spec/drawing for this type of installation.
TULUM
TULUM
RE: INcoming cable support/tubing
As a sample see the figures 17 to 19 on the enclose site. Beware that this could be different for each utility company.
h
