Simulation of large structures
which software is suitable for simulations of large structures (10x10x10 m) at frequency of about 5 GHz. The most software tools can not handle with such large number of unknowns caused by this high frequency.
Applications:
-human in some room: BAN
-two antennas in closed structure: communication inside of some sensitive body.
I know WIPL-D, HFSS and CST. WIPL-D can not because of limited number of unknowns. HFSS is frequency domain tool but I need time domain like CST. Have somebody done some experience in this topic?
For all proposals I will be very thankful.
Applications:
RE: Simulation of large structures
Google GTD UTD and ALDAS to start.
Not sure how well it will work for non-metallic humans. MIght be able to set upper and lower bounds though...
It sounds like antennas on aircraft.
If you're having reflection problems off structures causing ripples or phase uglies in an interferometer array, my company has some interesting thin peel and stick absorber products that absorb rf energy at veriable angles all the way up to grazing incidences.
kchiggins
Toyon Research Corporation.
Higgler - I'm working with Toyon right now on a set of GPS antennas for the GIF fuze. Nice to meet you.
