Standard for Acid Etch of High Temp Steel
Does anyone know of a standard or spec which describes this process?  We are looking for grinding burns.
Bill
William E. Blum
Manager
NDT Consulting Group Inc.
www.ndt-cgi.com
wblum@ndt-cgi.com
USA 1-877-638-2441
Fax/Voice Mail 1-214-853-5131
Sweden 46-42-14 39 99
RE: Standard for Acid Etch of High Temp Steel
What is the high temperature steel chemical composition - stainless or a nickel-base alloy?
For grinding damage control of austenitic materials like high temperature resistant steels the current testing methods would preferably be the Magnetic Barkhausen Noise Analysis or possibly eddy current inspection.
http://www.welding-advisers.com/
Take a look at FAQ178-1111
Vita sine litteris mors est.
Nital or ammonium persulfate etching is appropriate when checking for overheating of high carbon martensitic steels, such as carburized steels or alloy steels like 4340.  Some heating above the tempering temperature will cause the steel to darken when exposed to the acid etch procedure (overtempered), and more heating will cause a white spot surrounded by darkening (re-austenitized and quenched).  The two industry specifications I know are AMS 2649, "Etch Inspection of High Strength Steel Parts" and AGMA 2007, "Gears- Surface Temper Etch Inspection after Grinding".
AMS 2649 is being revised by AMD Committee B, by the way.  Should you have any questions or want to suggest changes, contact Committee B through the SAE webpage, or send me an e-mail (I'm not hard to find) and I'll pass along the comments.  Regarding the AGMA spec, here's the information from their webpage-
ANSI/AGMA 2007-C00 Surface Temper Etch Inspection After Grinding [Same as New ISO 14104]
Explains the materials and procedures to determine and evaluate localized overheating on ground surfaces.  Includes a system to describe and classify the indications produced during this inspection.  However, does not provide specific acceptance or rejection criteria.  Revision of  ANSI/AGMA 2007-B92.
ISBN:  1-55589-761-4 Pages:  6
Hope this helps!
