Write Protected File
I am trying to save a file to a CD.  The file keeps getting saved as write protected / read  only.  Even though, the option to open as read only is not selected.  I can save it to my hard drive without it being write protected.  Any help would be appreciated.
RE: Write Protected File
CD-R by it's nature is read-only.
Do you have CD-RW?
corvette63,
Try saving the file from the CD onto your harddrive and then "right-click" it. Go to "Properties" and uncheck Read-only. As IFRs has stated, CD-R's are read only. By saving it onto your harddrive you can edit it's properties and use it as you want.
