NDE Solvent Welded Pipe Joint PVC or ABS
Are there any techniques to NDE a solvent welded pipe joint. Materials such as PVC and ABS are joined by this technique whereby the pipe in put into the bore of a socket. I was after a method by which one could examin the coverage of the solvent weld to determine if it was complete?
RE: NDE Solvent Welded Pipe Joint PVC or ABS
