Looking for Wood Moulding Profiles
Anybody have a suggestion where to look for wood moulding profiles? At the very least I need the dimensions, but cad models would be just fine as well. Crown, chair rail, hand rails, etc. I did a search on the nest but no luck.
Thanks in advance for the help.
Cygnas
Cygnas
When it comes to protecting yourself or your family it is better to be judged by 12 than carried by 6.
RE: Looking for Wood Moulding Profiles
208.56.50.249/pdf/MoldingProfiles.pdf
http://archmillwork.com/home/am1/smartlist/20/0
www.
Do a search in Google to find more.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
Thanks again,
Cygnas
DWG files then can be put onto a sketch and used to make extrusions or create weldment profiles.
The website is : http://www.muenchwoodwork.com/pages/ProSta.htm
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.0
Check it out at: ht
Best Regards,
Jon
Chris
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
Thanks again,
Cygnas
Chris
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
Thanks very much!
Cygnas
Insert the dwg into a new part, delete the lines etc that are not needed for the extrusion, then you can select all the line entities and move them to the origin. You could then add all the relationships to make it fully defined, or what I do is select all the enitities and add a Fixed relationship so they don't move on me.
Furthermore this profile could be saved as a weldment profile. Look in help on how to do this.
The benefit of creating a weldment profile for these is that you can create several different cuts at the joints.
Best Regards,
Jon
