Translational Stiffness Estimates for Expansion Joints
I am modeling some steam piping in a stress program and need to input translational stiffness information on some expansion joints.
This is a typical problem I have run into before. I found some old catalog information, but I don't have good confidence in it.
Does anyone have any suggestions?
I am not comfortable with modeling the joint as "free" in all directions.
Thanks!
Thanks!
RE: Translational Stiffness Estimates for Expansion Joints
Also, some of the manufacturers standard literature that I have found don't publish this information. I have found that you have to buy the joint and then you get the EJMA form with all the data.
The problem is -- I am trying to figure out where and when I need flex joints -- my stress model doesn't converge if I give the joints too much freedom and I'm thinking that if I give them a stiffness, it will help with convergence.
Be sure to anchor your system to make piping move in direstion to take advantage of expansion joint
You should be able to download the senior flexonics catalog here and get some reference values for lateral, axial and angular spring rates:
http://www.myej.net/Catalogs/MetalCatalog.pdf
Edward L. Klein
Pipe Stress Engineer
Houston, Texas
"All the world is a Spring"
All opinions expressed here are my own and not my company's.
