Modeling of honeycomb panels, CATIAV5R14
Hello again.
I am trying to model honeycomb panels with aluminium material to it.
Is there a way to make a sort of "smaller file" ...
Problem; honeycomb size about 0.188inch wall thichness 0.010inch panel thickness 0.5inch, 13inches X 65inches. File is mega big when changing parameters values on either one of the above values. It takes forever to update and I have a not too bad workstation. Is there a magical "honeycomb option" somewhere ???
Louis
Louis
RE: Modeling of honeycomb panels, CATIAV5R14
Lee
http://www.lmco.com
I need to see the stress points at the adherence contact where the epoxy weld will be made/glued.
I was thinking of a flat sketch then thick extruded ?
What do you think ?
Louis
What about a simple pad with a rectangular pattern of pockets?
Lee
http://www.lmco.com
