Transport Truck Radiator Pressure Drop?
I'm piecing together a cooling system for an engine test lab, and am looking at using a transport truck radiator. Does anyone know approximate flow rates and pressure drop for these? I've been looking all over the web and without luck. I know that they can dissapate around 10,000 Btu/min, which is more than adequate from what I am using, but I'd need to know the other info for pump sizing.
RE: Transport Truck Radiator Pressure Drop?
Maybe this will help anyway:
A Cat 3306B DITA (200..300BHP) for marine use has a coolant pump that moves 53 gpm at 1800 engine rpm at 15.7 feet of water.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
Lay your radiator flat on a table (or preferably in a big sink).
Connect a hose to one of the radiator connections.
Connect the other end of the hose to a known volume of water.
Raise the volume to a known height above the radiator, time how long it takes for the water to fall out.
Repeat for other heights.
MintJ - thanks for the advice, I might take that on once I get said radiator, but currently I'm wondering what type of donor vehicle to look for in a scrap yard.
Later
Quote: "Its not what you know, its who you know" - anybody trying to find a decent job
