Versioning Table for As Saved
Can anyone post this section or point me to a resource that has an example of a versioning table for the ug_english file? Im looking for one that will drive the "As Saved" option under load options. I want to use alpha-numeric versioning. Heres how I would like to name my parts and have versioning find the latest. Heres an example of some revised names.
ug.5000e480.01.0a.prt, ug.5000e480.01.0b.prt, ug.5000e480.01.0c.prt
Thanks again,
    GG
RE: Versioning Table for As Saved
Examples are in the ug_english .def file.
This is what our section looks like.
Our part numbers are in two forms:
12345678.00.prt or 12345678.c.00.prt
!           **          PART NAME VERSIONS          **
! The following rules are used to describe the part names
! the system will use when searching for the version of a
! part for an assembly. The syntax for the rules follows
! the Regular Expressions used by the UNIX system. Leaving
! the rules blank means the system does not recognize
! versions of files and will compare complete part names
! when searching for parts.
! Examples follow.
! This pattern specifies the general format of versioned
! part names.
Assemblies_PartNameFormat: ([0-9]+\\.)([0-9][0-9]|([0-9][0-9sm]|([a-e]\\.[0-9][0-9sm])))
! This value decides which portion of the
! Assemblies_PartNameFormat rule is the
! version independent portion of the name.
! It consists of 2 back-slashes "\\"
! followed by the number of the section.
Assemblies_PartNameSubstitution: \\1
! This value is used to match all versions of a part in a
! directory.
! It consists of the  Assemblies_PartNameSubstitution
! rule specifying the
! version independent portion of the name along with the
! section of the
! Assemblies_PartNameFormat rule specifying the pattern
! for the part version.
Assemblies_PartNameMatch: \\1([0-9][0-9]|([0-9][0-9sm]|([a-e]\\.[0-9][0-9sm])))
! Assemblies_PartNameMatch rule
! is the version portion of the name.
Assemblies_VersionSubstitution: \\1
! This value decides the sorting order that will be used
! to determine the latest
! version of a file if several exist.
! Note: A valid option must be specified even if file
! versioning is not being used.
! Valid options are:    [MILITARY,NUMERIC,REVERSE_NUMERIC,ALPHABETIC,REVERSE_ALPHBETIC, ALPHANUMERIC]
!  where:
!  MILITARY            :  1 < 1.2 < 3.2.1
!  NUMERIC             :  2 < 5 < 11
!  REVERSE_NUMERIC     :  15 < 7 < 2
!  ALPHABETIC          :  a < m < z < av < ff
!  REVERSE_ALPHABETIC  :  z < a < vv < aa
!  ALPHANUMERIC        :  a2 < a5 < b2 < b23 < aa12 < bc22
Assemblies_VersionType: NUMERIC
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
