Print Madness
Print Madness
Print Madness
I'm having some difficulty understanding the whole Page Setup/print thing.  I have all of our drawings set exactly the same, yet for no apparent reason, sometimes settings change.  All of my drawings are set to "use this document's settings" and nobody ever touches that.  So, how does it change?  Anybody else struggle with this?  Thanks,
Brian
RE: Print Madness
I could be a result of your Printer itself, SW simply uses the windows printer format. So your driver of the printer you are using maybe set differently and is causing the setting(s) to change. Try a different default printer or change the actually printer setup at the windows stage.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
