Heatsink problem
Heatsink problem
Hello guys,
I have a problem on heatsink.
There are 2 given: fin and column heatsinks.
What are the advantages of the column over the fin one?
I can just think of the disadvatage--smaller surface area.
Thank guys.;)
Thank guys.;)
RE: Heatsink problem
For forced air designs, the biggest factor is usually air bypass: air takes the easiest path and goes around instead of through the fins. Try to minimize bypass and maximize surface area. The optimal design depends on the fin or pin thickness and spacing, surrounding geometry, air pressure source, etc.
ko (www.ecooling.biz)
I did forget one other advantage of the pin fin sink: it looks more "high tech". If the appearance and the marketing of your product is more important than the thermal performance, choose the pin fin sink. If it really is for decoration only, you can buy pin fin sinks molded out of plastic! No kidding.
conditions.
pin fin heat sinks:
-Work almost as well when vertically oriented as when horizontally oriented. This can't be said of plate fin heat sinks.
-Work pretty good when upside down.
-Provide more surface area for a given volume of heat sink material.
-When an optimized plate fin array and an optimized pin fin array occupy the same volume, the pin fins are superior in both natural convection and forced convection.
-Because the pin fin array provides more surface area it radiates more heat per unit area for the same temperature.
Would you like a scholarly paper with references?
Tunalover
Yes, I've seen several articles favoring pin fins and I believe your points are generally correct. However, it really does depend on the application. Plate fins can perform better with directed forced air when pressure drop and/or air bypass is a concern. And they typically cost less.
