Blast Pressure Calc for Pneumatic Test Chamber
I am designing a blast chamber to contain potential failure of a pressure vessels tested with air. In order to do this, "the available energy released by isentropic expansion of the fluid from rupture conditions to one atmosphere" must be calculated. I'm more than a little rusty on thermo!
The largest vessel that will be put into the chamber would be 400 gallons, at ambient temp(60degF) and at a test pressure of 404.7 psia.
Can anyone help me?
Any other info on this would be helpful too.
Thanks.
Can anyone help me?
Thanks.
RE: Blast Pressure Calc for Pneumatic Test Chamber
P1= Vessel or piping pressure, psia
P2= Atmospheric pressure, psia
V1= Volume of vessel or piping, ft3
k= Ratio of specific heats (k= 1.66 for He; k= 1.41 for H2, O2, N2, and air)
The internal energy “U” can be compared with the potential energy release in TNT. One pound of TNT contains the explosive equivalent of 1,551,000 ft-lb. (LLNL ES & H Manual)
The pressure from a blast can be approximated, if you care to obtain this additional data, by using Hyde’s equation (referenced in several Internet sources).
