API valve/bonnet connection
For API vavle, do we have to use studs and nuts to connect the bonnet (for actuator) to the valve? I am think about using socket head capscrews to connect them, will this violet some industry standards? I did not find anything metion about using bolts in API 6A, but in ASME B16.5, there are certain limitations to use bolts, ie. have to be hex head etc.
Thanks a lot.
Thanks a lot.
RE: API valve/bonnet connection
hope that helped.
