SolidWorks Viewer and PDF
I have a 3-sheet SW 2005 drawing file. In SW, I can print to the Acrobat Distiller printer driver and get all 3 sheets in a single PDF file.
Another employee here has the SolidWorks Viewer installed so he can see and print native SW drawings. He tried printing the 3-sheet file to the same Distiller driver (installed on network server) and can only ever get one sheet as output, even though his Print Preview shows all 3 and he chooses to print All pages.
Is the Viewer crippled for some reason, or just way too basic for fancy stuff like this?
RE: SolidWorks Viewer and PDF
I have not used it, but my boss uses Acrobat Distiller to create our SolidWorks dwgs on-line. I do not know how he does it, but it creates all sheets together in one PDF file. There must be a setting in Acrobat.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
It may be a pain, but you can print each sheet separately to PDF and then use Distiller to combine into a single file.
TheTick ... How do you print each sheet seperately in SW?
see also Thread559-122404
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
