Excel runs slowly on computer
Frequently, my Excell workbooks get very large because of added worksheets and data, and then they run very sluggishly on the computer.
What is the best way to upgrade a computer to solve this? More RAM, faster processor chip, both, or what?
RE: Excel runs slowly on computer
Cheers
Greg Locock
Cheers
Greg Locock
How much RAM?
What OS?
How many other processes running?
What version of Excel?
How big are your Excel files?
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
I am referring to 4 different computers.
Excel 97 (I have no use for the fuzzy icons and other sillinesss associated with Excel 2003)
RAM varies from 256K to 1G
Operating systems - Win98SE, Win2000, XP Pro
CPU- Athlon 1700+, Pentium 3 GHz, more or less.
The "slow" machine- Win98SE+Athlon1700+256K is almost as fast as the more recent ones.
I am not that savvy about other processes running. The more recent machines have many running, most of which are a mystery to me.
The Excell becomes sluggish at about 20Mb size.
1. If your spreadsheet contains mainly data with some lookups and simple calcs, then a database program may work better.
2. If it's mainly calculation then consider splitting the spreadsheet into separate functions
3. If it's truly monolithic (all calculations, all inter-related) then such an old version of Excel may not be the tool for the job.
It sounds from your first post <q> because of added worksheets and data </q> that a major overhaul of the design may be in order.
Good Luck
johnwm
To be honest I'm moving away from spreadsheets for anything that has to be maintainable and is safety related.
Cheers
Greg Locock
It has a moderate amount of data tables, lookup, match, offset functions. It has a very large amount of formulae, with a lot of "branch points" (not really savvy on the lingo here). There are no macros, nor VBA involved. Minimal graphics. I don't understand what you mean, "split into separate functions".
It does the complete design of a wood framed building. When, for example, there are more shear wall designs than it is set up for, one simply copy/pastes new worksheets into the workbook.
I don't have the time or the mental fortitude to learn Database. Just keeping up with our Building Code is a challenge.
I will consider upgrading to a later version of Excel. I didn't know that could be an improvement.
Greg:
It is in a constant state of being upgraded, with more features. That is not an easy task.
Maybe I've lived a sheltered life but a 20mb Excel file seems really big. Are you comfortable with knowing what you have in the file justifies its size? I've known that Excel files can get corrupted causing bloated file sizes and still be able to open.
htt
Just something to think about if you haven't already. Is your target workbook file size increasing proportionately to the size of the worksheets you are adding?
Sometimes , the project calculation workbook can become about 20mb in size. Typically, it is more in the range of 6-10mb.
I have tried the Save As (under different file name). That does not seem to have any effect.
This workbook is continually "tweaked". I have been able to clean it up on occasion by carefully copy/paste just the occupied cells of a worksheet onto a blank worksheet.
Another thing that helps is making sure the "Control-End" last cell is really the last cell of data in the worksheet.
Admittedly, since I am not an Excel expert, there probably is a lot of inefficiency (redundancy?) inherent in the workbook formulae, data, etc.
Electricpete:
The machine with 256K runs Win98SE, and is not connected to the Internet. It rarely hangs or crashes, so I figured it is doing just fine...and it seems only a little slower than the 3 other machines I use.
Come on now, think about it. The early 8088 PC's had 512K ram if memory serves me right.
On the subject of making your file smaller:
1 - check out thread770-80600
2 - As johnwm said, consider breaking your file into smaller pieces. You can still have a one-way lookup to get data from a file that is closed on the disk (use filename and "!" before the cell reference). Also you can provide a hyperlink in on file to open another excel file. I store data on 30 different machines in 30 different spreadsheets. I have one master spreadsheet that extracts summary data from each of the 30 and displays it along with a hyperlink to open the individual file for more details. It may not be applicable to your situation but it helped me keep my files manageable.
You found me out - I wondered if I had some form of dyslexia, or it was just a "grammatical" mistake!
TTFN
I tried putting the fixed data on another workbook, but it had little effect.
