PMDC Motor Conversion
I have a 300 watt PMDC Motor that runs with the following profile:
24 VDC
850 RPM
13 Amps
~400 oz-in
8 Pole
32 Slot
The motor is no longer available, but I have found a similar motor that is the following:
36 VDC
2500 RPM
12 Amps
4 Pole
16 Slot
Will it be possible to rewind this armature to achieve similar results to the original motor? If so, what direction should I take as far as wind data?
Efficiency is important in this application, and must be kept as high as possible.
Many Thanks in Advance
24 VDC
850 RPM
13 Amps
~400 oz-in
8 Pole
32 Slot
36 VDC
2500 RPM
12 Amps
4 Pole
16 Slot
RE: PMDC Motor Conversion
BK
I have very little room to move as far as design changes.
