Help finding the magnetic properties for 440C
Hi. Does anyone know of a source for the magnetic properties of SS type 440C? Thanks.
Help finding the magnetic properties for 440CHelp finding the magnetic properties for 440C(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Help finding the magnetic properties for 440C
One more thing to put in the new book.
Hardness?
Corrosion resistance?
Magnetic? What type of magnetic properties are you concerned about?
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
http://www.magnet.fsu.edu/
The Br and Hc will be dependent on the heat treatment. This could cause some large variations.
I tried to contact cartech and they said that they wouldn't know because it usually doesn't come up in typical applications of 440C and that the info should be in the public domain. However, I haven't found anything yet.
It is assuming that they will be used as permanent magnets in the full hard condition.
I have no data on the effects of tempering. My hunch is that the Br will increase and the Hc decrease. No idea by how much though.
You are going to need to have some samples tested.
You might try contacting Walker Magnetics or Magnetic Instrumentation http://www.maginst.com/
They both build test equipment and I am sure that for a nominal charge they would do some testing for you, or at least send you to one of their customers that could do it.
htt
http://emat.eng.hmc.edu/database/database.htm
The BH curves in this web site was taken from the ASM metals handbook revision 8
