Rules for truss layout
As a structural engineer designing wood buildings, I sometimes cannot determine the correct or "best" way to lay out trusses of a complicated roof.
Is there anything printed, or available on the Internet as a guide?
RE: Rules for truss layout
http://www.alpeng.com/wood_truss_info.html
http://www.trussteel.com/trussteel.nsf
Nothing about layout, but a gold mine otherwise - thanks!
Girder trusses for hips should have a uniform setback. That way the jacks can all be the same....assuming the same pitch applies.
Next look at the span of the trusses. If they must only have 2 bearings then that's the way it is. But if at all possible then use multiple bearing walls.
Bear in mind that most truss manufacturers can only make a 12-14' tall truss. Then it becomes a base with a cap.
Rememer the more information that you supply the better the trusses are. Don't assume anything.
This is just my 2 cents worth.
These guys are the ones who work hand in hand with the end user. They should know what works in that market and what doesnt.
If anyone from central Florida wants to hook up with a truss designer, try Casmin, Inc. in Leesburg. They have been around over 20 years and the designer they have dedicated to my company is one of the best I have ever worked with. I can count on him to find problems or questionable areas.
